Lookout
how to change control panels with combobox or listbox
i would like to know if i can pull up control panels with a combobox or listbox instead of using buttons
Message 1 of 13
(5,622 Views)
It's 6.0.2 file.
You need to create 2 combobox separately in 2 panels and add the connections. Use the SelectedItemIndex property.
Ryan Shi
Message 2 of 13
(5,609 Views)
okay i kind of have it working....i'm not wanting to close the main control window and i do want to close the popup windows i am opening with the combobox with a close button....i tried putting a second combobox on the popup window and made it not visible....this kind sort of works...is there any way to delay how fast the windows pop up when the selection is made in the combobox....or can you make the selection in the combobox and then have to press a go button for the window to pop up...thanks..randy
Message 3 of 13
(5,593 Views)
Ryan Shi
Message 4 of 13
(5,582 Views)
thanks...that's the ticket.....only one more thing...is there a way to put "Select  A Screen" in the combobox and it return to this when you close the popup instead of it just being blank...randy
Message 5 of 13
(5,579 Views)
Ryan Shi
Message 6 of 13
(5,574 Views)
that's exacty what i wanted...thanks so much....how do you get so smart with this stuff?....
Message 7 of 13
(5,563 Views)
okay i told a story...one more thing...how would i take i guess a couple of comboboxes and a go button (kinda like the one at the top of http://www.galottery.com/ ) and make it open the excel spreadsheet i log items to for that day or whatever day i choose...thanks..randy
Message 8 of 13
(5,548 Views)
Do you mean that you have many xls files that named with the date? such as 2006-6-1.xls?
What do you mean by "open the excel spreadsheet"? just open it with excel or import the data into lookout object?
Ryan Shi
Message 9 of 13
(5,519 Views)
okay i have a spreadsheet object that logs how much of different aggregates and how much cement is put into a batch for concrete blocks...i think i set this up in the spreadsheet object (not sure) but is saves them as a csv file under a year folder which includes the month folders and then the day folders...every day it makes a new day folder and when the month rolls over it makes a new month folder.......when you open up the day folder and double click on the file, excel opens it up.....i was wondering if i could make a couple comboboxes for the month and day with a go button  to open the files according to month and day....is this possible....thanks..randy..i appreciate all your time
Message 10 of 13
(5,517 Views)
