Lookout
how to protect the source code in lookout
we are using the lookout 6.5 version for the automation. we want to protect the code from the end user, please confirm the possibility of the same.
(6,082 Views)
The .lks file is the source file. If you give the .l4p file to end user, and the end user uses the runtime only server, they cannot modify anything. But actually they can modify the process if they have development server.
Ryan Shi
(6,071 Views)
is there any that even with development server also end user cannot access the source code.
(6,044 Views)
Create a user account with low security level. In Lookout, Option->System, configure the security level for "Menu bar ...." and "Menu and title ...." so that this user cannot access the menu bar.
Ryan Shi
(6,036 Views)
