Lookout
alarms not displaying in alarm window
I have a couple systems displaying the same problem. After running for a while (sometimes an hour, sometimes a day) legitimate alarms no longer show up in the alarm window. Both systems are Windows XP Professional with Lookout 5.0. Usually after re-booting the PC a few times the alarms show up for a while again.
I need to know what it is that governs the alarm display, and what I can do to fix this.
I have confirmed the database path settings are correct.
I have confirmed that the computer name specified in Lookout matches the computer name specified in Windows.
I have confirmed the process is selected under the Alarms menu.
I have the confirmed the alarms filtering is set to Alarms Only, and I'm sure none of these change after running the PC for an hour or so.
Any further ideas?
Has anyone else come across this
Message 1 of 1
(5,556 Views)
