Lookout
how to query the citadel database
Is there a way using Lookout to query the citadel data base?
I have value that is being saved every second say, into the citadel database
a specific record may look like this for the field
MON_DS  = "7:57"
Local Time  =  "2/19/06 15:59"
I want to have the user enter a date and then lookout to query the citadel database and find the
maximum value for MON_DS for that date.
Is this possible in lookout?
I can download the data to a spreadsheet but that is alot of work to load each of the fields & local time records
frank
(4,245 Views)
Hi Frank,
It's been a while since I have done this, but it is (was??) doable.  You will need to use the SQLExec Object.  I must further warn you that the query syntax used is rather esoteric.
The following KB articles may come in handy:
Syntax For SQL Commands For The DataTable And SQLExec Objects In Lookout
Good luck!
-Khalid
(4,236 Views)
Thanks Khalid,
I understand the structure of the SQLExec object, but how do i display the number that i am looking for?
The query should retrieve a value from the field defined in the SQLExec object but how do i display it?
frank
(4,213 Views)
Hi Frank,
You would use the "c" datamembers (see below), of the right datatype:
SQLExec Data Members
Data Member Type Read Write Description
c1 – c65535 numeric yes no Value of the nth column in the row returned by ODBC.
c1.logical – c65535.logical logical yes no Value of the nth column in the row returned by ODBC.
c1.txt – c65535.txt text yes no Value of the nth column in the row returned by ODBC.
-Khalid
(4,204 Views)
