Lookout
hypertrend trace in lookout5.1
Dear all,
I am now using Hypertrend to display the value of an expression( for instance Exp1) The Exp1 is regarded as analog variable and the minimum value of it is 0. I just want to display Exp1 on Hypertrend when its value is bigger than 0 and hide the trace just in the duration Exp1=0. Anyone has any ideas about this? Thanks in advanced!
(3,461 Views)
Use NI Hypertrend object. Object->Create->ActiveX->NI Hypertrend.
In NI Hypertrend Properites, set the minimum to 0.1. Then if the value is 0, you won't see it, althought the value is logged into database.
Ryan Shi
(3,454 Views)
Thank you a lot Ryan for your kind help
(3,446 Views)
