Lookout
lookout alarm object
also lookout decides the high and low level
Message 11 of 13
(3,729 Views)
Create a Pulse. On/Off = Alarm.active. Period = 02:00:00, duration = 01:59:59.
SCADAlarm monitors the Pulse, instead of Alarm.active.
The Pulse will be ON when alarm.active is ON. The difference is that it will turn off and on every 2 hours.
Ryan Shi
Message 12 of 13
(3,721 Views)
Accepted by ecx1000
Ryan,
That worked great, it works just the way i wan't it to. Thank you very much for your help and i also thank Mike for his help also. Both of you guys are great.
Message 13 of 13
(3,716 Views)
