Lookout
nasty error massage “ illegal operation “
I am trying to edit an old application for a customer. I installed Look Out on an old PC that is comparable to the machine that the application is currently running on. When I try to open the app I get a nasty error massage “ illegal operation “ Details= “ LOOK OUT caused an invalid page fault in module KERNEL32.DLL at 015f:bff7b997.  Help!
(6,110 Views)
What's your lookout version and OS?
Try to open the LKS file with a text editor (i.e. Notepad). Copy-and-paste the entire contents of the LKS file to a new LKS file. You can just create a txt file and change extension to .lks. Open the new LKS file in Lookout. This may solve your problem.
If you just launch lookout.exe, will you get the crash?
Ryan Shi
(6,091 Views)
