08-29-2007 02:39 PM
08-29-2007 05:06 PM
Randy,
What do you have set up and how do you track the load being mixed completion? Is it the same amount of materials each time?
How do you track and by what do you use to track a new load that arrives? Is it the same amount each time?
It is easy either way but it is important!
Cory
08-30-2007 09:45 AM
08-30-2007 10:00 AM
08-31-2007 07:14 AM
08-31-2007 08:21 AM
Without seeing your running program it is hard to explain. It wqould be a series of text inputs latched by pushbuttons to add or subtract the amounts. If I could access it I could easily set it up. If you feel comfortable with that I can do it remotely. Lookout tracks every keystroke anyway. Let me know. You have my emaill address above.
Cory
09-18-2007 02:50 PM
09-18-2007 03:29 PM
Look into the pot object. It is just a value that can be volume, weight or whatever. The pot can have connections for value, increment, decrement, reset etc.
Events, pushbutton, timers and endless other items can be used to manipulate the value. Display is also easily done.
Bob
09-22-2007 02:13 PM
10-03-2007 03:17 PM
