Lookout
Communicating with an Allen-Bradley ComapctLogix processor over Ethenet
What are the requirements for communicating between Lookout and an AB CompactLogix PLC?
The communication will be Ethernet to the Compactlogix PLC.
This is an existing application where Lookout communicates to an Automation Direct PLC via Ethernet.
We are adding a new AB Compactlogix PLC to the system.
(5,124 Views)
Lookout doesn't have built-in driver for CompactLogix PLC.
You need to use 3rd party OPC Server, such as RSLinx. Lookout can act as OPC Client.
Ryan Shi
(5,118 Views)
Does Lookout 5.1 support OPC?
IF it does, then we would need RSLinx OEM, that has OPC.
Thanks for your help.
(5,111 Views)
Yes, Lookout 5.1 has OPC client object to connect OPC server. It's opc 1.0 and 2.0 compliant.
Ryan Shi
(5,106 Views)
