Lookout
niopc
I have installed lookout 6.2 onto XP service pack 2 PC,
the PC is not connected to a network
I can start the NIopc server and add or remove tags without a problem
When I run the quick client I get  the square for the server and it goes green
the message box below says that it has connected to the server but no tags are displayed
from lookout I can connect to the server but it only shows the server but I cannot open it to show any tags
(6,775 Views)
After you connect to the server and got the green square, you need to create group and then items. Take a look at the help of Quick Client.
Ryan Shi
(6,759 Views)
yes I tried that but still the same problem
this has only the one green square
every thing I tried hasn't worked
I installed it onto one of the standard work laptops and it worked ok
all the submenus appeared
I could add tags without a problem and see hem in the quick client
quick client would automatically create any new tags
and lookout connected without a problem
(6,747 Views)
Could you give a screenshot of the quick client?
What happen if you add a group and then a tag?
Ryan Shi
(6,731 Views)
adding group or tag doesn't work
here is a screen shot
(6,703 Views)
I see the channel connected to server, but I don't see the group and tags. To add the group, select the channel, and Edit->New Group, or click the button on toolbar. And then select the new group, and Edit->New Item to add items.
Did you add the group and tags? What happened when you add the group and tags?
Here is a screenshot for your reference.
Ryan Shi
(6,699 Views)
