Lookout
no communication from modbus secondary
I am using a 1732 RTU as the remote unit and a 1739 for the main tied to the computer  thru comport 1
when running outlook it get a error "no communication from modbus secondary"
(3,611 Views)
Hi desalvo,
I need some additional information on your setup.  When you are trying to establish communications with your modbus device, what Lookout object are you using?
A good getting started guide for establishing communications to Modbus devices through Lookout is located here:
[broken link removed]
Matt S.
Application Engineering
(3,597 Views)
Also review the NI document for the 1700 series of Zetron Controllers, very simular.
(3,576 Views)
