Lookout
pager garbled response message
I am getting a "garbled response" alarm when i try to dial the modem with the pager object. The mode dials fine in hyperterminal. Using Lookout 5.0
(3,459 Views)
Have you tried increasing the Receive gap under Options>>Serial Port Settings?
(3,459 Views)
There are two Dev Zone documents that may be helpful. They cover some steps that you could follow.
"Lookout and Dial-Up Modem Settings"
"Using the Lookout Pager Object"
(3,459 Views)
