Lookout
problem with aggregate a cw knob object
hi,
i want use a knob with 4 pointer as aggregate,first i make a knob with 4 binding and 3 pot ,it work properly,then i write in the url of pots \null,next,i save as aggregate my process and export the value of pots as data member ,next,in parameter,i add the url of pots,then make a new project with 3 pots and add the aggregate that i built, and for parameter ,for example ,write "maxi.value" .
now whe change the value of pots in sorce project ,the pot in aggregate panel change ,but the value of binding related with same pots(other pointer of knob ,not change,why?
i attach the main and aggregate project in the zip file.
can anybody help me?
Message 1 of 1
(5,663 Views)
