Lookout
remoted pot overwrites values
After upgrading to Lookout 4.0 an reconfiguring my application to run as a
server client process in Lookout my remoted pots overwrite values in the
OPC connected PLC with zero. This normally should not happen, remoted pots
should receive the value from the remote source. It did not happen in 3.8.
Has somone got a solution?
(3,530 Views)
Make sure that the process.lst file does not exist in the same directory as
the process file when you open and compile the process.lks file. For some
reason, this has solved the problem for us.
a>server client process in Lookout my remoted pots overwrite values in the>OPC
connected PLC with zero. This normally should not happen, remoted pots>should
receive the value from the remote source. It did not happen in 3.8.>Has somone
got a solution?>
John T. Sampson
(3,530 Views)
