Lookout
totalizing a flow rate but not calculating if a negative number
I know how to take a flow rate and produce a totalizer using an integration. What I would like to do is not calculate the integration if the incoming rate should be a negative value. Thanks in advance for your help.
(3,285 Views)
hound,
you may use an EXPRESSION OBJECT to eliminate negative values, something like:
if(YourSignal.value>0, YourSignal.value, 0)(if the value of your signal is greater than zero, use your signal, else zero)
and connect the output of this object to INTEGRAL.
Hope this help
JPSS
(3,275 Views)
