Lookout
what can I to run the system only with DAC card +accessories + lookout software
That configuration for speed up and simplifing of system.
(2,943 Views)
____________________________
Are you asking about NI's DAQ hardware and Lookout? The only way Lookout talks to DAQ hardware is via OPC. So, you'll have to use the DAQOPCServer for this. The speeds will obviously not be the same as when using DAQ VIs directly.
Hope this helps. Please provide more details if you have any more questions in this regard.
Khalid 🙂
(2,943 Views)
