Lookout
when using a maximum object how can you display the time the max happened.
I am using a maximum object to display maximum daily flow rate and am resetting it at midnight but I need to show the time the maximum happened along with the flowrate.
thanks for any help!
(2,972 Views)
The maximum object itself doesn't have a way to display the time.  What you can do, is to have an Time/Date expression where you will get the value every time there is a change in the Maximum object value. Another option is to export the values to Excel and then use the Recipe object to read from it.
Hope this helps
Ricardo
(2,965 Views)
