Lookout
why my lookout application gets curropted
I created a lookout application having active-x components like day picker. when i ported this application to another windows 2000 system all the diplays seems to be disturbed. Pls help me if u got any idea why it happened so.
(2,934 Views)
Could you give me more details like
- the version of Lookout,
- Which active-x components are you using, are they available in the Recommended folder in Lookout?
- Have you tried to recompile the application? (double click on the lks file)
Best Regards,
Remzi A.
(2,934 Views)
Hi Remzi,
I am using Lookout 4.5. the process was running fine in my machine. when i ported it to another machines those control panels having this active-x components were completly disturbed.
The active-x component which is causing the problem(i suppose) is the Microsoft Date and Time picker Control. That is not available in the Recommended folder in lookout.
Yes i tried recomlpiling the application using the lks file. but the result was same.
thanks for ur reply
toney
(2,934 Views)
