Lookout
xytronix
Hello Everybody,
                         I would to find a driver my webrelay model: x-daq-8a5-i. When I try from measurement and automation, add new network device he sends me the message:" the device you requested could not be found on the network"
Thank you for your help
(6,191 Views)
Accepted by garryarmand
I checked its spec and found the supported protocol:
Web Browser, XML, or Modbus/TCP
I don't think you can use MAX to connect the device. MAX is basically used for NI devices.
Do you have LabVIEW or Lookout? If it supports Modbus/TCP, Lookout is able to connect it.
Ryan Shi
(6,180 Views)
