MATRIXx
Automatic save in ascii format
Is there a way to set MATRIXx to save data in ascii format as default instead of binary (using command 'save')?
(8,961 Views)
Isn't there a Keyword {ascii}?
So I think the save would look something like:
save "mysbd.sbd" {ascii}
or something close. Should be in the online help.
Does this answer the Question?
Garrett Thurston
gthurston@foliage.com
Phone: 781.993.5540
(8,961 Views)
Ok! I have to refine my question.
I mean 'set MATRIXx to save in ascii without having to specify the keyword {ascii}'. So that the default is to save as ascii and if I want to save in binary i will specify {!ascii}.
PC
(8,961 Views)
Is there something in sbdefaults?
That is try showsbdefaults and see if there is something in there that would allow you to change this.
I have to appologise. I have no copy of Mx so it is a bit from memory.
if it is in there they you setsbdefaults and make the change. Not certain about the syntax there but should be in online help.
Garrett Thurston
Phone: 781.993.5540
(8,961 Views)
Garret,
Thanks for your reply. It looks like setsbdefault cannot force the defaults of the 'save' command.
However, is interesting that the 'save' command help says:
"Binary files are smaller, but they are platform dependent and are not necessarily portable across platforms. Specify ASCII format if portability across platforms is desired."
I guess maybe somewhere there is a way of forcing 'save' to save in ascii.
PC
(8,961 Views)
PC123,
You could create an alias. For example replace save {ascii} with a new name, say savea.
alias savea save {ascii}
Then to save the variable x to the file "save.xmd" you would use:
savea x "save.xmd"
Carl L
(8,961 Views)
