MATRIXx
How do I remove the "MATRIXx License Server" from my WinXP control panel?
I am running Windows XP and have a "MATRIXx License Server" applet that appears in my control panel. I have been unable to remove it. In the "About" window of the applet, the following information is given:
Flexlm Version 6.0 Copyright 1996-1998
Copyright 1996-1998
Globetrotter Software
San Jose, California USA
I looked briefly at the Macrovision web site (pointed to by the globetrotter link above), but there is nothing obvious about this.
(7,760 Views)
The MATRIXx License Server is part of the MATRIXx License Manager installation and is the utility that you use to manage the MATRIXx licenses, especially if you are using floating licenses. As of MATRIXx 7.1 the LM Tools utility is used instead, and it can be accessed from the MATRIXx category on the Start Menu. I would not recommend removing the MATRIXx License Server from the Control Panel, but here is a KB from the Microsoft website that gives instructions:
http://support.microsoft.com/default.aspx?scid=kb;en-us;261241&sd=tech
It mentions Windows 2000, but the steps are very similar for Windows XP. Once removed you will not be able to configure the license manager until you unhide it again.
Carl L
www.ni.com/matrixx
(7,760 Views)
I forgot to mention the name of the control panel extension. The MATRIXx License Server is called mtxlm.cpl.
Carl L
www.ni.com/matrixx
(7,760 Views)
