MATRIXx
SCXI-1127 in SCXI-1000 (scxi-1200) chassis running under LV 5.01.
Any help with configuration and sample programs will be very appreciated. Can this work together?
(7,180 Views)
What type of examples were you hoping to find? I see that you posted this question in the MATRIXx forum, but your question might be more in reference to using SCXI-1127 in LabVIEW 5.0.1.
If it is just SCXI-1127 in LabVIEW examples you are hoping to find, I suggest performing some searches in the Example Code Library to see if you can find anything of use. Also, I'm not sure of the examples that get installed with the version of NI-DAQ and LabVIEW that you have, but you might also want to browse through the LabVIEW examples as there are most likely some that you could use.
If you are looking more for MATRIXx type examples, please post back to this forum.
Jared A
(7,180 Views)
