MATRIXx
What is the equation of lead lag block implemented in System Build?
There is any manual or document that presents the equation for lead lag block implemented in System Build?
(9,180 Views)
I am not sure which lead lag block you are refering to as there is not specific lead lag block on the SystemBuild palette. On the dynamic palette there is a NumDen block that could be used to implement a lead lag controller. All of the blocks have a help button on the properties dialog. This help putton will take you to the HTML help, which will have some more details on the block.
Carl Ljungholm
www.ni.com/matrixx
(9,179 Views)
We do not use matrixx here, however, I am trying to understand a control block diagram written for Matrixx. It is a project that we are currently working. In this diagram, I have a block called lead lag with 4 constants parameters (LD, LG, RS, IV), one input and one output. Is it a standard or a library component? Or is it a customized (super block) component? If it is not part of Matrixx, I will ask the author how it was implemented. Despite a lead-lag is a very basic transfer function, I would like to know exactly what was implemented. I can not have any doubt regarding how the zeros and poles were define, or whether the gain in unity or not.
(9,179 Views)
It definately looks like a custom component. When you look at the heirarchy in the Catalog Browser you should be able to pick up some clues as to whether it is a component or not. There is a Component section of the Catalog Browser and if the block is a component then it should be listed there. If it is not an encrypted component then you should be able to right-click it in the Component view and choose Compent Catalog, how ever it is encrypted you would not be able to see the internals.
Carl L
www.ni.com/matrixx
(9,179 Views)
