MATRIXx
Insufficient memory to load catalog
I get the error message "Insufficient memory to load catalog" when trying to load a model in systembuild.
I'm running MATRIXx v6.3 on Windows 2000. The computer has 512M of RAM and I've not had this problem before.
Any ideas?
(7,522 Views)
This error might be that the computer at that moment is running out of memory. If you reboot the computer will you still have the same error? What else is running in your computer? If you check the memory usage in the Task manager, how much memory do you have left?
Thank you
Ricardo S.
(7,515 Views)
