MATRIXx
Is it okay to use SH96-96 cable in SCXI-1127 as a custom cable?
For SCXI-1127, there is no suggestion of cable to use directly connect from 96 HDI.  Is it okay to use SH96-96 cable to be custom cable connect SCXI-1127 to my custom PCB? If not, is there any suggestions?
(7,457 Views)
Hi Bonebone6880,
I just talked with some of our engineers and they confirmed that the SCXI-1127 has a standard 96-pin connector on the front.  That means you shouldn't have a problem using the SH96-96.
Just make sure that you send the right signals to the right lines and everything should work perfectly fine.
Best of luck!
(7,446 Views)
