Machine Vision
如何利用IMAQ Find Circles 函数对颗粒加标记?
我想利用IMAQ Find Circles 函数对圆形颗粒进行计数,要求可以在每个识别出的圆形颗粒上加一个小方框或小亮点作为标记,但不知道怎么加,效果图在附件中,谢谢。
Message 1 of 9
(4,751 Views)
Translation from chinese
I would like to use IMAQ Find Circles round particle counting function, requirements can be identified in each round particles plus a small box or a small bright spot as a mark, but do not know how to add the result graph in the annex, thank you .
Do you mean you want to plot the number of particles in a graph?
Message 2 of 9
(4,749 Views)
I just want to add a small box for each round particles as a mark,like I upload the image,not show the number of particles in the image.
Message 3 of 9
(4,747 Views)
Did you try using the overlay circle?
Message 4 of 9
(4,717 Views)
Message 5 of 9
(4,716 Views)
Thank you very much,but could you tell me how does this part work,.2010-05-20 00 18 47.pngI don’t understand the principle about this part,thank you.
帖子被T-shirt在 05-19-2010 11:24 AM
时编辑过了
Message 6 of 9
(4,682 Views)
This is how you define circle if you know the centre position and radius.The overlay oval requires a bounding box input. So you have to feed Top,Left and Right,Bottom.
Message Edited by muks on 05-21-2010 03:24 PM
Message 7 of 9
(4,652 Views)
Accepted by topic author T-shirt
Solved? If so mark the post that helped as the solution...:smileywink:
Message 8 of 9
(4,596 Views)
OK,thank you very much.
Message 9 of 9
(4,588 Views)
