Machine Vision
0xBFF6001F
Hi
Does it necessarily means that if a frame grabber passed the self test, it is under no fault? I am having a pci-1407 card and though it passed all the self tests it is giving error 0xBFF6001 "cannot detect recognizable video source" with ccir cameras. i am only having ccir cameras and i have tried 3 pieces of them with the same result. please note i have used that frame grabber with the same cameras for around 2 years and since no settings have been changed by me. The card was not in use for ~ 6 months and when i wanted to use it again the problem arises. Please help me out.
(3,522 Views)
Hi RVision,
                  R u sure it is not the problem with your cable. R u choosing the proper camera file?
(3,506 Views)
Hello RVision,
Have a look at this KnowledgeBase article about error BFF6001F “Cannot detect recognizable video source”. Follow these steps, and let us know if the problem persists. I hope this helps 🙂
David G
Sales Engineer - SE Michigan & N Ohio
(3,490 Views)
