Machine Vision
0xBFF69037
Also, did you try any of the other formats in that list of what's supported by NI-IMAQdx? Although the others are non-standard names, it would be worth checking if they worked. After looking into the code I noticed an inconsistency with our implementation concerning that particular format that could be causing an issue.
Message 11 of 26
(2,762 Views)
Nevermind what I previously said about YCbCr422_8, sorry! I looked into this some more and it seems that YCbCr422_8 is correctly implemented and definitely should be supported. I validated that YCbCr422_8 is working on several different cameras, so please let us know if you're still having issues with that pixel format name after you've changed it.
Message 12 of 26
(2,758 Views)
There is no 0xBFF69037. but NI-MAX is automatically closed..
if you don't support the format,
We are considering changing the format of theYUV422_packed. the foramt is supported..
Nick.
Message 13 of 26
(2,756 Views)
Yes, you're right.
There is no error messages.. NI-MAX is automatically closed when the grab is clicked..
NI-MAX doesn't support the YUV422_8, YCbCr422_8..
if NI can not support the format, we consider changing the format to YUV422_packed in our camera.
the format YUV422_packed is supported in our other cameras.
Nick.
Message 14 of 26
(2,753 Views)
We had changed the format  to YUV422 Packed. so we can get the image from NI- MAX..
the current setting is as following,
 1920x1080p, 60fps, 16bit/pixel. -> BW: about 2 Gbps.
After grabing the image in two days, the NI-MAX send the stream stop command to the camera.
Why does it happen?
Nick.
Message 15 of 26
(2,622 Views)
I just wanted to update this thread to say that the latest version of Vision Acquisition Software added support for YUV422_8 and several other aliases:
http://download.ni.com/support/softlib//vision/Vision%20Acquisition%20Software/February%202016/Visio...
Support for cameras using the following aliases for existing decoders:
  • YCbCr601_411_8_CbYYCrY
  • YCbCr601_422_8_CbYCrY
  • YUV422_8
  • YCbCr601_422_8
  • YCbCr601_8_CbYCr
  • RGB10
  • RGB12
  • RGB14
  • YUV411_8_UYYVYY
  • YUV422_8_UYVY
  • YUV8_UYV
  • YUYVPacked
http://www.ni.com/download/ni-vision-acquisition-software-february-2016/5801/en/
-Katie
Message 16 of 26
(2,507 Views)
According to the pixel format,
if the format of the camera is changed, there is no problem..
We want to know why NI MAX suddenly sends the stream stop command to the camera after grabbing the image in a few days..
Nick.
Message 17 of 26
(2,476 Views)
Hi Nick,
Do you happen to know ab approximate image count (based on your frame rate) that it is hitting when it stops?
Eric
Message 18 of 26
(2,473 Views)
Let us know which of cases NI-MAX sends the stream stop command while grabbing the image?
Nick.
Message 19 of 26
(2,466 Views)
The only situation I am aware of is if it encounters an error. Does MAX pop up an error when this occurs?
Message 20 of 26
(2,464 Views)
