10-02-2005 12:15 PM
I have use Labview 7.0 and NI-IMAQ for IEEE 1394 software, and conncet with Sony DCR-PC120 NTSC DV handycam. But when I use MAX to show the NI-IMAQ for IEEE1394 devices, it show a 61883 class bus devices, and when I click it. It show the following message:
1074364415 IMG1394_ERR_EDRV Cannot load the driver
what is it? and How could I do?
10-03-2005 12:21 PM
In order to use the NI-IMAQ for IEEE 1394 software, you must use an IIDC compliant camera. I could not find any documentation on Sony's website stating that the Sony DCR-PC120 NTSC DV handycam meets these specifications. This leads me to believe the camera is not IIDC compliant. Using a camera that is not IIDC compliant will return many strange errors like the one below. I recommend taking a look at www.ni.com/camera. Select IEEE 1394 for the Interface Type and click search. This will be a good starting point for cameras that are IIDC compliant.
Ryan M.
