Machine Vision
I have used  two usb cameras  im my LabVIEW program,after I run my program, the two image controls  show the same images and when I finish my program
a error dailog showing,the error number is -1074396016.I don't konw why the two image controls  show the same images,does one not work?does NI IMAQ for USB Camera
not support multiple camera acquisition?How I can use multiple camera in my LabVIEW program?
Help!
Best Regards,
Enquan
Striving is without limit!
(4,129 Views)
Hello Enquan,
I could see in the attachement that you have used only one "IMAQ create" function. Use two different IMAQ Create and give image names as Image_1 and Image_2. wire these image out to 2 different grab/snap functions. It will work for sure.
Suhas
(4,123 Views)
Hello Suhas,
Thank you for your response!
I have updated my program as your said,but just one image control can show the image,another image control  doesn't work(show nothing).
whatever index(0 or 1) I set when I use IMAQ USB Enumerate Cameras.vi,the image control constantly show the same image.I think just one is
in work,the another camera doesn't  work.
Enquan
(4,117 Views)
Hello Enquan,
Are you getting any error? can you send me the error code/ description?
Suhas
(4,099 Views)
Hello,Suhas
I have known why I can't acquire images by using two cameras simultaneously.
Because NI-IMAQ for USB Cameras doesn't support multiple cameras acquisition simultaneously.
Thank you anyway!
Enquan
(4,095 Views)
