Machine Vision
Possible bug in FindCoordTransformUsingRect
Hi all,
using the latest Ni development module under VB .NET, I noted a strange behaviour in FindCoordTransformUsingRect returned values after an exception condition.
I put this function in a Try.. Cach block so, if there is a blank image (missing part), the software doesn't crash. After a missing part condition, FindCoordTransformUsingRect is able to set a reference/measurement system, but it returns always the error code 31842. Why this ? How can I know, after an exception, if the FindCoordTransformUsingRect is doing the right job?
Thanks in advance
PS
the missing part condition is not the only exception cause, I can't prevent the exception, I can only manage it.
(3,771 Views)
no suggestions ?
(3,761 Views)
Hello satriani,
are you using IMAQ Vision 8.5 therefore?
RL
(3,721 Views)
Hello Raffaella,
I'm using the 8.5 version of Vision Development Module.
(3,716 Views)
