Machine Vision
1473R DMA timeout at high speed?
Hi Cheng-Kaung,
I would recommend posting to a new thread on the forums. Since this thread is a lot older, it won't necessarily be seen or responded to by the members of our community!
When you do that, could you provide some more clarity when you mean when you say the examples don't work? What specifically does not work about them? Are you running into errors>
It might be work your while to call us directly in technical support as well so we can help you out. You can call at 866-275-6964.
Thanks!
Rahul B.
Message 11 of 13
(1,951 Views)
I am struggling with a similar problem, I am also trying to acquire images with the PCIe-1473R and a Basler spl-8192 70km camera.
Could you solve your problem and do you maybe have an example code which you could post? Thank you very much in advance.
Kind regards
Antonia Lichtenegger
Message 12 of 13
(1,013 Views)
Hi Antonia,
I echo Rahul’s comment and recommend posting to a new thread on the forums. You’re post will have more visibility in the community.
Thanks!
Kale W.
Message 13 of 13
(995 Views)
