Machine Vision
1473R particle analysis
There is an example program in labview fpga. Particle analysis on 1473R is the program. This demo reads an image from host to fpga then finds particles on the image. İs it possible to change this program and combine with vision assistant on 1473R.so is it possible reading real time images that comes from camera link camera and find particles on images then we can see at image and partcles coordinates at host computer.
thanks.
(4,003 Views)
impect,
I'm not sure I fully understand your question. Are you referring to the Particle Analysis Report on FPGA example? If so, how is the behavior you desire different from the behavior of the example VI?
(3,946 Views)
