Machine Vision
Is it possible to switch a cvs 1458 wes7 to a Linux RT?
Is there a Linux RT image that I could simply installed on the CVS instead of the WES7 image?
Thank you,
Patrick
(4,616 Views)
Hello Patrick,
There is no easily process for switching from WES7 to Linux RT on our embedded targets. I strongly recommend you contact your regional NI sales representative to discuss your options.
(4,584 Views)
I wanted to know if afterwards we could do it by our own, without any exchange.
My local reprensentative said we could change it if it's before 30days of purchased.
i want to know if we can do it with RT images or thing like that.
(4,514 Views)
Hi Patrick,
As Earl mentioned, there is no easy process for switching between WES7 and Linux RT on our embedded targets.  May I ask why you will need both operating systems?  My recommendation is to use only one operating system if possible, otherwise you can use two separate targets.
Kelly B.
(4,500 Views)
Thanks for helping.
Just to clarify, I don't want to use two OS. I want to know if I can format my WES7 CVS 1458 and install a RT Linux 64bit Image instead.
I thought the CVS 1458 was physically the same "machine"....
Thank you,
Patrick
(4,483 Views)
@paubine wrote:
Thanks for helping.
Thank you,
Patrick
They are physically the same hardware, yes, but I think there are differences at manufacturing time between the two units (various firmware pieces and such) that would make it tricky to swap back and forth. It is not a use case that NI explicitly designed for and supports. I'd discuss your needs with your local sales person and see if they can find a solution to accomodate it.
(4,479 Views)
