Machine Vision
3D contour plot of an image
I want to plot a 3D contour plot of intensity in an image. I've attached a sample image. Awaiting for suggestions.
Thanks.
(4,804 Views)
Accepted by aveo
Hello aveo,
how about using the "IMAQ 3D View". Please see the attached code saved for LV2010.
Does this suit your application?
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,731 Views)
... or perhaps something like this with 3d plot (see the attachment). I suggest using "render window" since there is no data reduction.
K
(4,725 Views)
Hi Klemen
It works fine! Thanks a lot for the reply.
The contours on the surface of the apple are coming out significantly.
Is it possible to rotate ,the IMAQ3D view output, in different directions like in 3D plot?
Regards
Aveo
(4,717 Views)
yes there is limited rotation, though you can't use your mouse directly. Take a look at the "direction", "alpha" and "beta" parameters in the help section.
K
(4,714 Views)
Yeah i tried it out. This'll serve my purpose.
Thanks K.
Regards
Aveo
(4,707 Views)
