Machine Vision
About subpixel in imaqRake and imaqRake2
In imaqRake, we can use subpixelDivisions to set maximum number of subpixel divisions ,  but in imaqRake2,  I can't find any config to set subpixel divisions,
So,  Can any one tell me how to set subpixel divisions in imaqRake2?
Message 1 of 19
(5,009 Views)
unfortunately some of vision toolkit vi have some unused change rake vi do not support subpixel
after version 2 for rake 3 you can find sub pixel data in line result and inside the edge info I think in rake 2 still you can find it in edge info
see this array and inside clusters
Message 2 of 19
(4,990 Views)
hi-  If I may explain this more.Thanks
Message 3 of 19
(4,929 Views)
I want value RGB each of the pixels of an image in my red array .
thank you .
Message 4 of 19
(4,924 Views)
what is your means  want value RGB each of the pixels of an image in my red array .
also did you see the image I attech with name of rake
Message 5 of 19
(4,918 Views)
Yes - there is not  Diagram . if possible the diagram attach .
thanks .
Message 6 of 19
(4,910 Views)
try this my Friend
Message 7 of 19
(4,904 Views)
Thanks very much from youexcuse me ....Version of this program is it ??
Message 8 of 19
(4,897 Views)
for use this icon Must installing what vision of labview ??
I have Only vision Assistant..
Message 9 of 19
(4,895 Views)
I work with 2014 but I could send you a gimage of code you can use it in any version that have rake vi
Message 10 of 19
(4,885 Views)
