Machine Vision
About subpixel in imaqRake and imaqRake2
I work with 2014  too . but I could not that the runing.  my vi has the orror in this icon of "Rake 3".
Message 11 of 19
(1,990 Views)
I work with 2014 too but I could not runing that . has errpr icon "Rake3" .  As shown below.
Message 12 of 19
(1,990 Views)
your problem should be in ROI
run first time it will make error but image will be show then select one rectangle ROI in image
rung again you will be see the result
Message 13 of 19
(1,979 Views)
I dont now setting Rake3 .  you guidance more  me .
Message 14 of 19
(1,969 Views)
When the icon Rake3 to the next deleted runed and The image showed. The only problem is the part Rake3 .
Message 15 of 19
(1,968 Views)
As shown below.
Message 16 of 19
(1,966 Views)
ok do you have rake 3 or you have rake 2 in your LV version
Message 17 of 19
(1,962 Views)
Yes I have Rake3 but have not Rake2 .
Message 18 of 19
(1,961 Views)
Hi . The more I try to make it Rake3 correct  is not. Please do "help me.
Message 19 of 19
(1,919 Views)
