Machine Vision
Access camera connected to remote target like MAX
So, through MAX, I can expand "Remote Systems", click on my RT target, expand it, look at devices, click on the camera and see the image and change the attributes.
Is that behavior possible through a LabVIEW application running on the local target but without altering the RT targets's code. For example, can I put a URL into the IMAQdx Camera Session control?
(2,837 Views)
NI-IMAQdx currently does not support this feature.  You might be able to emulate this behavior by using the VI Server API, but it will not be easy.
Feel free to add this feature to our idea exchange.
https://forums.ni.com/t5/Vision-Idea-Exchange/idb-p/visionideas
(2,817 Views)
If I can parse that a little finer, you're saying MAX uses a private/unsupported API?
(2,814 Views)
I do not believe it is a public API.  We don't seem to have any customer documentation about it.
(2,809 Views)
