Machine Vision
Problem while using Hamamatsu c9100-13 camera with ni-1428 frame grabber.
I am trying to operate a Hamamatsu EM-CCD (C9100-13) camera through Labview 15. The camera is connected to a Phoenix Camera Link frame grabber (AS-PHX-B-D24CL-PCI32). I wanted to know which version of Video Capture Library for Labview will allow me to operate the mentioned camera through Labview and from where can I download it?
The mentioned camera is compatible with only DCAM-API driver version 13.10.4418 (https://dcam-api.com/downloads/#archive).
Are there frame grabbers that have associated Labview drivers? Do you have recommendations for the same?
(2,579 Views)
I imagine the latest version of the DCAM-API drivers will be compatible with LabVIEW 2015. The download for the DCAM-API driver version 13.10.4418 is on the page you linked. Are you running into problems with that driver?
All National Instruments frame grabbers will be fully LabVIEW compatible. If you are unsure which frame grabber is ideal for your application, I recommend talking with a National Instruments sales engineer to help you choose.
Have a great day,
Aaron Douglass
(2,534 Views)
