05-15-2012 04:12 PM
I am measuring a position and orientation of the object. When the object directly under the camera lens its giving correct position and orientation but when the object away front the camera lens(but the object is inside the image) its showing not accurate position. Is this problem because of camera lens or height of the camera is to high or am I missing any stages or ...
Software using=Ni vision builder 2011
Stages I did = Image acquiring, image processing, Region of interest, calibrating, Geometric pattern matching
Hope you have understood my question
05-15-2012 05:24 PM
I think its due to the distortion. But how to solve the distortion problem in VBAI?
05-15-2012 05:43 PM
Vision Builder AI features a calibration step that you can use to correct innacuracies introduced by lens distortion.
You'll get the best results by calibrating your system using a grid of dots.
To create a calibration, select Tools>>System Resource Manager.
You can apply it within the acquisition steps (Calibration tab), or by inserting a Calibration step.
I invite you to look at the Calibrate Image Step Example located in the examples folder.
Hope this helps.
Christophe
05-16-2012
06:47 AM
- last edited on
05-27-2026
09:53 AM
by
Content Cleaner
Dear Sir,
You can calibrate from a file that already in your Vision Builder folder to find.
here is some interesting Information about Calibrating with Vision to have more accuracy:
http://www.ni.com/white-paper/4127/en
