Machine Vision
Acquire Edge Points
I am pressing a tire against a clear plate and looking through it to see
the contact area that is created, and I am using Vision Assistant 8.6
to detect the edges of the contact area. However, the only way that
I have found to detect the edge of the patch is by using the edge
detector function to manually draw lines in the area where the edge
appears. Is there any way that I could detect more points quickly,
like using a rake method of some kind? Thank you very much.
Respectfully,
Austin Allen
(4,037 Views)
Oh and sorry for double posting but just to clarify, I am doing this
to acquire a bunch of points so I can use the caliper function to
calculate the area, as well as to be able to define the edge of the
patch using the coordinates of those points.
(4,029 Views)
Accepted by Excalibur33
If you use IMAQ rake function, you will be able to get the pixel coordinates of the edge you are looking for.
This funstion returns a cluster called Search Lines in wich you can find another cluster called edges containing these informations.
Hope this help
(4,020 Views)
Great, thank you very much!
(4,004 Views)
