Machine Vision
Acquire non-standard video with a 1410 .... why I've the 0xBFF6001F error?
I tried to acquire the video signal that you can see on the attached file (a snapshot from the oscilloscope) with an NI-PCI-1410 but....... why I still have the 0xBFF6001F error ?
This is an Angiograph Video signal...that is like a VGA Signal...
That signal is connected to a simple monitor that can show the image...so...why is impossible for us to acquire the images?
To have the same problem, you can try to acquire the GREEN signal from a Standard VGA connector, setting the PC on 60Hz@1024x768.
Thanks to all
(3,343 Views)
Here
is a link discussing the same error.Hope it helps
(3,330 Views)
Thanks Muks,
I read the article before submitting the question...
My problem is really different!
I haven't HSYNC and VSYNC signals, so I've to sincronize everything with the signal attached in my first post!
Is like a standard signal (see also http://zone.ni.com/devzone/cda/tut/p/id/3020) where the Clamp Start and the Clamp Stop are 0(zero) !
Please, if someone have a PCI-1401, can try to acquire one of the signals (R or G or B) without Hsync and Vsync (...so...not with the Board in Slave Mode...).
I'll wait for other suggestion.
Fabio
(3,319 Views)
Hi fabio,
                Got your problem.will try to achieve it.
(3,307 Views)
