Machine Vision
IMAQ Vision AVI create - file access denied error
Hello:
I am getting some really strange behavior with the IMAQ Vision AVI create function.  I am seeing the following error with the following file name or pretty much any other file name I try.  I did try to hard code the same file path name, and one time it worked, but another time it did not.  Anyone seen this error before?
I ask the user for the AVI file name using following simple code which is then fed to to AVI create fx.
Don
Message Edited by DonRoth on 07-28-2008 11:40 AM
(3,995 Views)
(3,992 Views)
Thanks to Eric Reid at NI, this problem has been solved.  One has to close access to the file prior to generating the new reference for the AVI file.
Thanks again to Eric.
(3,957 Views)
I've worked with Eric many times - he's one of our best!
Chris Bolin
LabVIEW Partner Program, CLA
(3,938 Views)
