Machine Vision
image processing while running hlgrab.c
when I run hlgrab.c  (c#Program File #National Instrumensts #NI-IMAQ #Sample #MSVC #Grab #HL Grab),
it naturally works good. However if I put image processing code between  errchk & (implot), visible window (result of image processing)
stop after 50~60 second.
I try to find the reasion to stop running, but I cannot find yet~!
Is there anyone to help me????
(3,329 Views)
Hello Superstar,
Do you get an error when the program stops running? You might want to check for buffer overflow if image processing takes a lot of execution time.
Vivek Nath
Machine Vision
(3,303 Views)
