Machine Vision
Active Time Variable Vision Builder AI
I want to confirm a question about the system variables. I am wanting to program an algorithm that will count how many faults occur within a set time and if the amount of faults reaches a specified number within this time limit send an alarm. Is the Active Time in system variables the amount of time the inspection state has been running or the whole time since the run inspection was triggered. Thanks
(3,576 Views)
Hi T.P Titherington,
The Active Time shows the time the inspection states have been running. Thus, this time will 'pause' when you stop the Inspection and resume when starting again (minus the idle time). To reset this you can use Inspection>>Reset Inspection Statistics.
DylanC
(3,566 Views)
