Machine Vision
monochrome DMK23G445 shown in MAX as 32-bit RGB
I have Monocrome Gigait ethernet camera DMK23G445.
When I press Grab in MAX under the image it shows it as 32-bit RGB camera(picture).
As a result I could not process it in my program as it requires 8-but mono picture.
Why MAX shows it like this? I have IMAQ-dx 4.0 drivers.
(3,869 Views)
Just check in the attrbute list in MAX that the pixel format output by the camera is set to 8bit. Otherwise, the camera is able to output 32bit images.
Regards
(3,868 Views)
In attribute it shows as options only 10-12-14-16 bit.
The strange thing is tha in MAX it shows this camera in 2 places and currently only bottom one works(yesterday middleone worked as well but picture was very much distorted). Middle one yesterday showed picture as 8 bit, bottom one as in attached screenshot.
If you try to open camera in Vision Builder then in the list of IEEE1394 and ET cameras only middle camera is shown. I could not use it as it does not work...
(3,866 Views)
Maybe you should have a look at these articles:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YM6JCAW&l=en-US
http://www.ni.com/white-paper/5750/en
Then sometimes it's better to remove the xml,iid and icd files located in "Documents and Settings/All Users/Shared Documents/National Instruments/NI-IMAQdx/Data"
Don't hesitate to remove all of them, they will automatically be uploaded the next time you connect the camer.
Hope this helps
(3,863 Views)
I already followed upper one guide. I managed to make camera working but image is distorted as in attachement. I have seen this on some other postts earlier. But do not remember a typical solution.
Why MAX shows camera in 2 places? Is one NI based driver and another manufacturers one?
(3,859 Views)
