‎05-14-2007 10:59 AM
‎05-14-2007 11:06 PM
I'm not sure why you would need to continuously redefine your pattern, but it would be difficult. Training patterns can take seconds, so you wouldn't be able to keep retraining the pattern with live video. In theory, it might work on batch processed images.
Bruce
‎05-15-2007 05:06 AM
‎05-15-2007 05:14 AM
‎05-15-2007 09:51 AM
Thank you for all the replies,
You are properly correct, it is close to a no win application I am trying to do.
The parts is not always exactly the same shape. I have already tried to traine on one part and the try to find it at the end of the conveyor without luck. I then made a test where I took 10 images 1 sec of part, and manually did a pattern training and a pattern matching 10 times, and in that way I could track the part. For the test I used Vision Builder, but if I somehow can do an adaptive training and pattern recognition, I understan that I have to use LabView.
When trying to find the part by its own at the end of the conveyor there are too many possibilities, but If I try do the pattern matching after 1 to 3 seconds, the image I try to recognize is almost the same as the one I tained.
thanks,
gert
‎05-15-2007 10:06 AM
‎05-22-2007 12:02 PM
