Machine Vision
Affine Transformation on image
I want to apply a affine transformation on a image. I know some (at least 3) points on the current image and the same points on the "new image" (after the affine transformation).
I can not use the function from matlab or opencv to perform the geometric operation and only find basic operation like rotation or translation in the vision module
Message 1 of 9
(8,610 Views)
You should look at the calibration functions. An affine transform is a subset of the perspective transform that the calibration functions provide.
Kevin
Message 2 of 9
(8,593 Views)
Thanks for your answer.
I actually manage to implement in labview the transformation affine and the estimation of its matrix, once I really understand the bilinear interpolation
Message 3 of 9
(8,561 Views)
Sometimes it is easier to work with image in the form of 2D array (especially if you are working with grayscale image).
In that case Functions>>Mathematics>>Geometry pallet should be exactly what you need.
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
Message 4 of 9
(8,532 Views)
Do you have a VI fo the affine tranformation? for 3 points?
Message 5 of 9
(7,885 Views)
Maybe kl3m3n posted something you're looking forward: https://decibel.ni.com/content/blogs/kl3m3n/2015/04/24/homography-mapping-calculation-labview-code
Message 6 of 9
(7,787 Views)
write the equation for affine transformation and solve it. You need 3 point pairs for this. If you have more points, you could use a least-squares approach.
If you don't like coding, you can use OpenCV's functions getAffineTransform() and estimateRigidTransform(), respectively. Just perform a .dll call - there are a lot of examples online.
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 7 of 9
(7,752 Views)
to help you a bit further, here is an example of calculating the affine transformation (least square), provided you know the three corresponding point pairs.
Hope this helps.
K
Message 8 of 9
(7,735 Views)
Exactly what I was looking for.  Thank you!
Message 9 of 9
(5,039 Views)
