Machine Vision
PCI-1422 icd file difference
I have a computer with a PCI-1422 board in windows 98 SE and NI-IMAQ 2.5.3.
When I acquire the image of my specific camera, the image is okay.
I have update in NI-IMAQ 3.0, I load the same icd file than the old configuration (config file NI-IMAQ 2.5.3)
When I acquire an image, the image looks non synchronize (when I start and stop grab many times the image is moving) like a problem of synchronization. But I launch a grab the image is not moving, but when I start and launch again the image is at an other position
I take a look at the icd file and I see that some parameters have been added when I load it in NI-IMAQ 3.0.
Do you know which parameters have changed between NI-IMAQ 2.X and 3.X because I think that I need to add attribute which are take by default in 2.X and need to be added manually in 3.X
Message 1 of 1
(2,306 Views)
