Machine Vision
After aquiring an image how do you convert or save it as an HDF file
I am using LV to acquire an image. Once I grab the image I need to save it as an HDF file so I can do some further analysis. Has anybody done this if so could you explain how to go about it?
(3,026 Views)
There is a LabVIEW toolkit that will enable you to edit and save files stored in HDF (Hierachical Data Format) You might consider reading the following knowledgebase:
http://digital.ni.com/public.nsf/websearch/CB8A7F8090900F6C86256CC700033816?OpenDocument
Will Denman
Application Engineering
(3,026 Views)
